I agree, the stiffer sidewalls of a ST trailer tire are there for a reason -- and I'm convinced that I should use them, partly because of the cooler run temperature you refer to. Not to mention LT (light truck) tires, which some swear are better for travel trailers, are not available in our 14" size.ChanW said:I believe it's desirable to have stiffer sidewalls in a trailer tire. They'll have less tendency to sway, and will run cooler due to less flex.
Lower tire pressure can also affect the temperature, though there's a possibility that the 65# pressure spec with the Goodyear tires might be only their recommended max inflation pressure. Likely you can run a lower pressure.
Sure, tire choice is personal, but our non-boondock trailers are designed for a certain user profile -- which we fit perfectly, as do you. Mostly highway driving, some back and side roads, no serious off-road use. NuCamp provides clear direction for the tire they think works for those design parameters, and puts that info on the VIN sticker. Should I really ignore that?Mickerly said:I agree balancing is probably a good idea although not considered necessary for utility trailers. It will reduce vibration in the trailer while traveling.
Tire choice is a personal thing and should be based on how you trailer is used. For example, we use our 320 for state park camping and travel on the highway. A tire build for speed and road use, like the Endurance is a good match. If you driving a lot on dirt roads, I would lean towards a more agricultural tire like the Hercules (made by Cooper tire sold through tractor supply and feed stores) intended for on and off road.
Like batteries, tires come in many different designs and levels of quality. Rather than trying to match tire pressure, look for something based on how you use your trailer. A two year replacement seams short. What is happening with your original tires?
Denny16 said:The nüCamp OEM tires are also stiff side, most ST (trailer tires) have stiffer sides compared to auto tires. The stiffer side on trailer tires also helps to reduce trailer sway.
yes, they do -- of course!!! and the heavier, higher load rated tires have even stiffer sides. A "C" rated ST tire (OEM) is certainly less stiff than a "D" or "E" ST tire.... and less stiff than a tire with a higher inflation.
Well, Pintoplumber, if you'd just spoken up earlier you could have saved me from a week of waffling ;<)Pintoplumber said:I have Carlisle tires on my 7000 lb car hauling trailer and on our Keystone Outback 21RS. I’ve had no problems with them and will put them on our 320 CSS when the time comes.
