Bedding
hikerchickhikerchick Member Posts: 34
What size mattress do you use or pillow top ? I had thought when I watched video that you could use a true queen but the dimensions are 5 inches off on the width.
  • subkronsubkron Member Posts: 196
    If you google "rv queen mattress" or "rv short mattress" you will see what is available.  The width for those is the same as std queen (60"), the length is 75" vs the queen std of 80".
    2022 T@B 400 Boondock
    South Jersey
  • hikerchickhikerchick Member Posts: 34
    So are you using a queen mattress?
    Personally we are still using what was supplied with the T@B (froli and mattress). Depending on the mattress or topper, a queen could probably be compressed to fit.
    South Jersey
    The TaB400 (at least on the 2018/2019) rear bunk is about 56”x79”, we use queen sheets, and had a queen topper cut down to 56x78 inches.  Works well, without crowding the space and cutting off the Alde air circulation vents in the back.
  • I found that a Full XL mattress topper is a near perfect fit (Measures 80" L x 54" W) with a little bit of room around the edges to put on your fitted sheet and to stuff your blankets down around the sides.  I bought mine from Bed Bath and Beyond, but I don't see that size available now.  I use queen sheets but they are quite a bit too big, but they work with a little tucking and stuffing.
    @hikerchick, which Tab do you have?
  • MaxcampMaxcamp Member Posts: 348
    Measure your bed area.
    We bought nominal 3" foam topper at Walmart on our inaugural trip, a soldering gun and foam cutting tip to size it.  (A drywall knife and straightedge will make ragged edges.)  Queen sheets do not span widthwise adequately on 320S, needed King.  Full mattress coverage can cork up all the radiant heat in cabinets below, leaving the cab cold.
    Just fyi, the easiest way to cut a foam topper is to use an electric knife. It makes a perfect straight edge and even cuts better than a hot knife and is much safer to use by us novices. This is a tip/trick passed on to me by a professional upholsterer decades ago. It is how I cut our (originally) queen sized gelfoam topper to fit our 320 t@b sleeping space.
  • KimmieGuyKimmieGuy Member Posts: 28
    I leave the bed out all of the time with a custom made topper on top.  It’s a lot to be honest, but I have RA, and I love SOFT.
     Cute… poor Kermit!
