My 2021 T@B 320 Boondock S has a leak on the cold water line under the sink where it connects to an elbow. I haven't encounter clamps like the ones used at the factory and I don't know the best way of removing them so that I can make the repair. I will replace the clamp with a screw/ring type. What is the best way of removing the clamp? Thank you
The clamp tool is easily found in any Plumbing Department these days
managed by VE Smart Network
It is possible that you could just tighten the crimp on the existing clamp with the proper tool. It is also possible that you may have to replace a fitting or section of hose.
There is also another style of clamp, but the tool is much larger and probably more difficult to get into the area.
Brad
Concord, NC
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
The water expansion in our Airstream trailer was from the water heater, but it may also be from cold water warming up as the trailer interior warms.
I solved the problem, not by tightening fittings and clamps, but by adding a small water pressure expansion tank. I placed it under the sink by disconnecting the cold water supply and hooking it to one side of the expansion tank, and buying and adding another supply line from the expansion tank to the cold water faucet. No more leaks.
The little water pressure expansion tanks are available at RV stores and Amazon. I'll add one to our new T@b 320 soon.
Doug K
Minnesota and Arizona
Here's the one I installed in our Airstream:
https://www.amazon.com/SHURFLO-182-200-Pre-Pressurized-Accumulator-Tank/dp/B000N9VF6Q/ref=asc_df_B000N9VF6Q/?tag=hyprod-20&linkCode=df0&hvadid=312739500877&hvpos=&hvnetw=g&hvrand=17235574251872259912&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030132&hvtargid=pla-434846988215&psc=1
Doug K
Get one of these tools - they will easily cut the clamp. It's still tough to pull these apart. The type of plumbing clamps to use is subject to many opinions. I've found that the pinch style clamps are the easiest to use and rarely fail if you install them correctly (and use the correct size clamp). In my opinion, worm gear clamps are probably the worst to use - they tend to get over tightened. I replace a lot of those. The push to connect fittings are good too, but they are expensive. I use those only when I can't get in a space with a crimper. The white shark bite fittings are tough to push together all the way. It's also easy to over tighten the screw collar.
Certified RV Technician
jomrvt.com
2021 T@B 320 CS-S
If you do go "p to c" read the instructions on how deep a full connection is and then make a Sharpie mark on your hose so you will know when you have fully inset the hose into the fitting.
