Is this video correct on adding water from a container? 2022 T@B
CCC
Member Posts: 118
https://www.youtube.com/watch?v=vZ8NbuxjNj4At the dealership yesterday the tech told me you couldn't fill your water tank this way, that it would only go to your fixtures. I pressed him him on it but he couldn't give a more detailed response.
2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia
North Georgia
Yes, this video is correct to fill the tank using the water pump.2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure1 -
Once he Nautilus valves are set correctly…. Details are in the Nautilus manual.
In the manual there are two ways to fill the fresh water tank. Page 6 shows how to fill the tank with a hose from the city water connection. (Green left, blue down on the valves).Page 7 shows what the video is showing. Same valve settings as the "city water tank fill" above. The pump does the job for you. You might have to hold the container higher to get a little siphon action going to help prime the pump a bit.
That was exactly what we did to rinse out our Fresh Tank with a little Bleach.
Out of a 5 gallon bucket0
