Is this video correct on adding water from a container? 2022 T@B
https://www.youtube.com/watch?v=vZ8NbuxjNj4
At the dealership yesterday the tech told me you couldn't fill your water tank this way, that it would only go to your fixtures. I pressed him him on it but he couldn't give a more detailed response.
2022 T@B 320 S Boondock  "UGA", Jeep Gladiator Overland
North Georgia
  • Maple_Geek
    Maple_Geek Member Posts: 217
    Yes, this video is correct to fill the tank using the water pump.
    2022 T@B 320S Boondock
    2021 Toyota RAV4 TRD Off Road
    Ottawa, Ontario, Canada
    Instagram: new.t@bventure
    Denny16 Member Posts: 5,430
    edited April 2022
    Once he Nautilus valves are set correctly…. Details are in the Nautilus manual.
    pthomas745 Administrator, Moderator Posts: 4,700
    In the manual there are two ways to fill the fresh water tank. Page 6 shows how to fill the tank with a hose from the city water connection. (Green left, blue down on the valves).
    Page 7 shows what the video is showing.  Same valve settings as the "city water tank fill" above.  The pump does the job for you.  You might have to hold the container higher to get a little siphon action going to help prime the pump a bit.
  • screwlose
    screwlose Member Posts: 18
    That was exactly what we did to rinse out our Fresh Tank with a little Bleach.
    Out of a 5 gallon bucket
