Just wanted to share a gift that was given to me at Christmas. This drill size Ryobi air pump (with digital display) came in handy here in New Mexico after a recent camping trip and follow-up re-winterizing exercise on our T@B 400 here at around 4300’ elevation in high desert. Temperatures dip down into the 20’s at night so before I placed my trailer back in storage I went through it, dumped all water in the tanks, installed some pink RV antifreeze in the gray & black tanks and blew out the remaining water in the lines using this pump that I had brought out with me. It did the trick and I was glad I had it with me as otherwise I planned to use a bike pump.
4 ·
North Texas
Trips - 45 Mileage - 57,106
North Texas
I have that same Ryobi. Did you have a fitting that worked with a blowout plug?
Camco RV Brass Blow Out Plug | Helps Clear Your RV's Water Lines During Winterization and Dewinterization (36153) https://www.amazon.com/dp/B0006IX68O/ref=cm_sw_r_cp_api_i_ZWKE2EEH5E4T68X5S1PN
I've got the same Ryobi inflator/deflator. I used the hi volume/low pressure inflator side to try and blow out the Nautilus P3 on my '21 TAB 400. It seemed that with the valves in the "V" position to clear out the P3 harness, the sound indicated that the air flow was blocked, so maybe the pressure was inadequate to clear the lines. Did you try that function before you used the high pressure/low volume side? I didn't think that side would work because there's so little air volume to blow the lines, but I'll check it out.
North Texas
