Window material
geoB
Member Posts: 114
I'm curious - what are the windows made of? Or, who is the manufacturer? I'm thinking about remedies for cover-induced scratches and I want to be sure not to make things worse. Could be that worse is the only available path!
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
Specs site Acrylic dual pane windows.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I've had good luck with Meguiar's plastic products.Rich2019 T@b 400
On two separate annual occasions, I’ve successfully used Turtle Wax Polishing Compound to remove shallow scratches from the windows of my T@B 400. I apply this compound with an electric orbital polisher. It takes a little time to do its work, as I believe the compound is slightly abrasive. The results have been very pleasing to me; clear, bright windows.
https://www.turtlewax.com/products/premium-grade-polishing-compound-18fl-oz
Thanks for all the suggestions. I'm going to start with Novus products since they appear to be targeted for acrylics. If those don't work I'll expand my horizons.
Truckee, CA, expat, now driving out of Reno -
@geoB You might try the Meguairs #10 and 17 , I've had good results by hand for the minor scratches we've had. Used a tarp for a while instead of an actual cover and that was a mistake, regular cover hasn't caused any new scratches.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
I have used the Novus combination of three solutions to remove scratches and clean the windows. They work very well!
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
