Cleaning Windows - T@B 320-S Boondock
We picked up our T@B yesterday and the dealer mentioned that we would need a "special product" to clean the windows as Windex type products will make them foggy. There are still stickers on the windows from the factory as the dealer did not have this "special product". Rain-X was mentioned.
Can anyone recommend what to use the clean the windows?
Thanks!
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
  • webers3
    webers3 Posts: 436
    Windex type products will make them foggy, hmmm, that's interesting
  • mona
    mona Posts: 246
    Use nothing acidic if you want the windows to stay clear. And product containing ammonia or vinegar is a no no. Windows are not glass, they are acrylic.
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
  • B11
    B11 Posts: 42
    Still awaiting delivery of our 2022 400bd so I can't speak directly about cleaning the acrylic windows on our camper. However, I did own motorcycles with acrylic fairings. I would recommend using a very soft cloth like an old cloth diaper, terrycloth or a microfiber towel. Be certain the surface of the window is clear of dust and the towel is clean. Wipe with less pressure. I used a product called S100 Special Surfaces Cleaner on my fairings and helmets. No scratches or fogging. This is what I intend to use when/if we get our camper.
    https://www.amazon.com/S100-Special-Surfaces-Cleaner-Spray/dp/B008R9A3A8
    2022 T@b 400bd
    2022 F-150
    Gratitude
    pthomas745 Posts: 4,648
    Some of the FB groups are convinced that only Plexus should be used.  My windows are fine after years of car wash soap and a very soft cleaning cloth.
  • Aubrey
    Aubrey Posts: 160
    Plexus is all i put on my Harley windscreen, works great! Glad I read this, now I can use it on our T@B 400.
  • CrabTab
    CrabTab Posts: 457
    To add another option, we used Novus Plastic Polish in the shop during my 'productive years'. Below is a link to a video from their site. I keep the small size bottles handy to clean up any scratches (usually from road debris).
    NOVUS Plastic Polish (novuspolish.com)
    2019 320 Boondock Edge
     - Sold Jan 2022
  • Da_Birds
    Da_Birds Posts: 133
    I've been hesitant to take it to car wash mostly because of the windows. Do you apply wax? I'm actually surprised how clean it has stayed and so far I've only had to spot clean some areas but eventually it's going to need a good cleaning and I assume a coat of wax.
    By "car wash soap" mean just your ordinary "car wash" detergent that can be bought in any auto parts aisle.  Tab owners have literally used every possible combination of simple to overpriced car wash products.  I use Meguair's Finishing Wax on my cars and the trailer.
    There are many threads....
  • Docbadger1
    Docbadger1 Posts: 15
    I only use Plexus and a clean microfiber cloth on the windows. It helps keep the windows in good shape and hide the scratches the dealer put in the windows cleaning them for my pick up. If the windows are really dirty you should probably wet them with clean water first and then the Plexus. It will work great on the trim too. I also use Wash and Wax All on the rest as it does a good job of making Bernice shine. These are products used for aircraft and very similar materials used on our RVs.
  • db_cooper
    db_cooper Posts: 749
    For simple cleaning on the road,  I've used Windex with no issues, so suprised to hear that's a no-no.  If there's a lot of grit on the windows I don't clean them until I can wash the windows first, otherwise you're going to scratch them with the dirt.
    For deep cleaning I've used the same thing I used on my first gen Mazda Miata's plastic rear window,  Meguairs #10 polish and  #17 cleaner.
    https://www.amazon.com/Meguiars-10-Plastic-Polish-Cleaner/dp/B0002VAZ34
  • Parlando
    Parlando Posts: 165
    I worked as an art gallery director for many years.  For cleaning Plexiglas we always used one drop of Dawn detergent in water with a soft flannel cloth, followed by a clean rinse of clear water water with a soft flannel cloth, and finally dried with a dry water with a soft flannel cloth. I've heard that these windows should be wiped in one direction only, either horizontally or vertically. I'll probably do that as well, as it can't hurt.
