Cleaning Windows - T@B 320-S Boondock
PixandMsBee
Member Posts: 34
We picked up our T@B yesterday and the dealer mentioned that we would need a "special product" to clean the windows as Windex type products will make them foggy. There are still stickers on the windows from the factory as the dealer did not have this "special product". Rain-X was mentioned.
Can anyone recommend what to use the clean the windows?
Thanks!
Thanks!
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
Windex type products will make them foggy, hmmm, that's interesting
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut0 -
Use nothing acidic if you want the windows to stay clear. And product containing ammonia or vinegar is a no no. Windows are not glass, they are acrylic.2015 T@b S Max white with silver trim. 2018 GC Trailhawk.2
Still awaiting delivery of our 2022 400bd so I can't speak directly about cleaning the acrylic windows on our camper. However, I did own motorcycles with acrylic fairings. I would recommend using a very soft cloth like an old cloth diaper, terrycloth or a microfiber towel. Be certain the surface of the window is clear of dust and the towel is clean. Wipe with less pressure. I used a product called S100 Special Surfaces Cleaner on my fairings and helmets. No scratches or fogging. This is what I intend to use when/if we get our camper.
https://www.amazon.com/S100-Special-Surfaces-Cleaner-Spray/dp/B008R9A3A8
2022 T@b 400bd
2022 F-150
Gratitude1 -
Some of the FB groups are convinced that only Plexus should be used. My windows are fine after years of car wash soap and a very soft cleaning cloth.
Towed by 2014 Touareg TDi2 -
Plexus is all i put on my Harley windscreen, works great! Glad I read this, now I can use it on our T@B 400.0
To add another option, we used Novus Plastic Polish in the shop during my 'productive years'. Below is a link to a video from their site. I keep the small size bottles handy to clean up any scratches (usually from road debris).
NOVUS Plastic Polish (novuspolish.com)
2019 320 Boondock Edge - Sold Jan 20220 -
pthomas745 said:Some of the FB groups are convinced that only Plexus should be used. My windows are fine after years of car wash soap and a very soft cleaning cloth.
I've been hesitant to take it to car wash mostly because of the windows. Do you apply wax? I'm actually surprised how clean it has stayed and so far I've only had to spot clean some areas but eventually it's going to need a good cleaning and I assume a coat of wax.
2021 T@B 320CSS Boondock - "Chirping Bird"2018 Chevy Colorado - "Dad's Truck"1 -
By "car wash soap" mean just your ordinary "car wash" detergent that can be bought in any auto parts aisle. Tab owners have literally used every possible combination of simple to overpriced car wash products. I use Meguair's Finishing Wax on my cars and the trailer.There are many threads....
Towed by 2014 Touareg TDi1 -
I only use Plexus and a clean microfiber cloth on the windows. It helps keep the windows in good shape and hide the scratches the dealer put in the windows cleaning them for my pick up. If the windows are really dirty you should probably wet them with clean water first and then the Plexus. It will work great on the trim too. I also use Wash and Wax All on the rest as it does a good job of making Bernice shine. These are products used for aircraft and very similar materials used on our RVs.
2 -
For simple cleaning on the road, I've used Windex with no issues, so suprised to hear that's a no-no. If there's a lot of grit on the windows I don't clean them until I can wash the windows first, otherwise you're going to scratch them with the dirt.
For deep cleaning I've used the same thing I used on my first gen Mazda Miata's plastic rear window, Meguairs #10 polish and #17 cleaner.
https://www.amazon.com/Meguiars-10-Plastic-Polish-Cleaner/dp/B0002VAZ34
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
I worked as an art gallery director for many years. For cleaning Plexiglas we always used one drop of Dawn detergent in water with a soft flannel cloth, followed by a clean rinse of clear water water with a soft flannel cloth, and finally dried with a dry water with a soft flannel cloth. I've heard that these windows should be wiped in one direction only, either horizontally or vertically. I'll probably do that as well, as it can't hurt.
- 959 Air Conditioning & Refrigeration
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
