So on my 2019 I didn't need pressure regulator to flush black tank. The connection was right there at the black tank. On the 22 it's inside the Nautilius so that makes me think I need the regulator for the black tank flush now? I used it just in case but I only have one so having to move it from fresh water hose over to blank tank flush hose and would rather not do that, so need to know if needed so I can order another one. Thanks!
0 ·
2019 320 Boondock Edge - Sold Jan 2022
I've used mine with a regulator at the spigot and without a regulator. Both options appear to work fine as with the regulator on I did not seem to notice a change in how the nozzle spray sounded vs without the regulator. I guess what I'm saying is that if there is already a regulator attached to the hose there is no need to really remove it prior to flushing but if there is not one hooked up I would not bother attaching one prior to flushing.
Here is a link to my source: Do the 2021 or 2022 Tabs have a built in water pressure regulator (vanillacommunity.com)
Glad you got it sorted. Adding a pressure regulator to the black flush doesn’t hurt anything, and offers some additional protection.
