Porthole window service
I have a Tab400 that I purchase used last year.  Looks like previous owner used silicone sealer around port-hole windows, which looks to be less than good quality.  I am looking to correct this potential leak issue and wondering if anyone has removed and replaced one of these windows.  I am concerned about the degree of difficulty and whether or not I should have this work done by a dealer.  Can anyone give me some insight on this?
  • Paul1959
    Paul1959 Member Posts: 27
    Thanks Sharon!
  • manyman297
    manyman297 Member Posts: 1,436
    If you can remove the silicone and the window is fine, just apply some geocel 2300 sealant (that's what nucamp uses). It's really sticky so use mineral spirits and a finger to tool it.
    Now if you're removing the entire window I think it's being held on with butyl tape or some other kind of adhesive sealant tape. Use a plastic putty knife to break that seal.
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • Paul1959
    Thanks manyman!  I have elected to have this checked out by a dealer.
