2021 400 bdl. De winterizing hooked to city water with pressure reducer I began to flush all lines of antifreeze. In hot water mode the galley sink first had antifreeze and then turned a white bubbly fluid and then clear. The out side hose in front of the drivers side front stabilizer was pouring out clear fluid that stopped after the city water was shut off. I drained the low point hot and cold water as well as releasing the 2 yellow Alde pressure valves. Upon removing the panel around the Alde expansion tank I noticed it was empty. BTW I had checked the tank prior to the whole process and the fluid level was fine. To me it appears water has breached the Alde glycol envelope but have no clue as to how? I spoke to Alde and they thought it could be a connection or a void. Of course I am less than a month out of warranty. Any advice?
0 ·
I can not locate pictures of the drainage tubes under the 400. Can you go under the bed and check the Alde?
A big shout out to NuCamp customer service for making this happen, the dealer was poor at communicating with me and my guess NuCamp also. I only had the initial email explaining the problem with customer service and a follow up inquiry.
