Alde Beeps?
manyman297
Member Posts: 1,433
I couldn’t find an answer to this question but what does it mean when you attempt to set the hot water on the Alde 3020 panel to “more hot water” and the panel beeps three times? We were heating the water with electricity using the 2kw setting. Everything works fine but didn’t know what the beeps meant.
2021 400 BD
2020 Tacoma TRD Off-Road
From the Alde 3020 manual:19. SoundProvides audible alerts in different situations:• Button for sound On and Off,• Audible signal when hot water tem-perature is reached when Alde Flow* isinstalled and more hot water is selected• Audible signal in the event of “Gas Fail-ure”.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks @Sharon_is_SAM. I was looking at the manual and probably just overlooked this. I assumed it had to mean the hot water was ready but wasn’t entirely sure.2021 400 BD
2020 Tacoma TRD Off-Road -
Yes, means hot water is already ready to go and is already boosted and hot.
It sounds like the sound is only supposed to be audible when the Flow is installed.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I don't ever recall hearing a beep on our unit when the hot water is on. Maybe I've just never been inside the camper at the time it beeps?2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
It takes about 30 minutes I've found after first turning it on upon arriving at camp, but if you are already using the Alde for heat, I've found it beeps (3 times) as soon as I push the boost for the Alde Flow indicating the water is already at the set temperature and ready to use.
And yes, the beep is only an indication for the Alde Flow. -
I'll have to turn mine on and wait inside to hear the beep!2021 T@b 400 BD "Vixen Gail"
Hmm, positive our 2019 400 has never beeped. The Alde flow auto reverts to normal operations after 30 minutes, but no sounds at all. Wonder if the sound versions are only certain years or an option? It is possible there is an option to turn around on too buried in a menu choice someplace?2019 T@B 400 Boondock Lite
My prior 2019 400 also beeped as does my current 2022. I bet there is a way that sounds can be turned on/off.
Does the 2019 have the 3020 or the 3010? Maybe it only beeps on the 3020?2021 400 BD
The 3020 in the 400 started to be installed with the December 2017 builds (2018 models). The Flow became standard with late 2019 models.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
