no power with shore power plugged in
llovejoyllovejoy Member Posts: 1
edited January 2023 in Battery/Electrical & Solar
We are plugged into shore power with our 2014 T@B but do not get power with my electric water heater plugged in.
All else seems to work.
  • newcampnewcamp Member Posts: 63
    Did you check the breakers (inside the black panel on the front of the driver's side sofa seat)? If any of them is switched opposite of the others, switch it back.
    That would be my first place to look...
    2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,013
    The outlet may be on a separate circuit.  Flip the circuit breakers and also see if there is a GFI that needs to be reset.
    When you say all else works is that include any other 120v outlets? All the 12v items like lights do not count as they could be running off your battery.
    Make sure 120v is actually getting to trailer before going down a rabbit hole.
