Carry extra water front Tab BD
homerdhomerd Member Posts: 37
You can fit 2 reliant 7 gallon water boxes. They fit pretty good. From Walmart $20 each
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
  • Grumpy_GGrumpy_G Member Posts: 684
    Nice. Those with lighter tow vehicles need to keep in mind it adds over 100 lbs to the tongue close to the hitch point.
  • homerdhomerd Member Posts: 37
    Yes, but I mounted my rear tire on the back of my tab in a carrier so I wanted some hitch weight!
  • AnOldURAnOldUR Member Posts: 1,696
    homerd said:
    … I mounted my rear tire on the back …
    Sounds like you may be OK, but if you can, please measure your actual tongue weight with the containers full and report back here so that others know what to expect with this setup. Thanks!
    Without water, weighed at 207#. All gear in boxes and trailer including 10# full propane bottle. With H20 will be around 325#. I like it
    10# is additional bottle
