Air8 Blue screen won’t even light up 😆
KimmieGuy
Member Posts: 28
Hi! Tab320, 2020 model, living and loving the dream. However, I cannot get the AC to turn on, not even a screen, this first trip out of the summer season. I treat this lil camper like my baby, and have always done everything on the level, and serviced with the dealer each fall. Can’t figure this one out. I’ve tried new fuses, and flipping breakers. I’m lost. Any thoughts or suggestions are GREATLY appreciated! ☀️🧐
If everything else is working, look for a loose connection behind the panel.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Also, just found another thread on this same problem. The Air8 gets plugged into a GFCI. Check to see if it tripped.
https://tab-rv.vanillacommunity.com/discussion/11039/dumb-question-about-2020-tab-400-air-8-elwell-control-panel
Oh thank you so much for your kindness! I am super happy that Tab folks like you reach out to help. 😊 I am going to pull apart the back end of the camper tomorrow and check connections. I pulled up the half mattress and checked the side floor tonight, but nothing jumped out as loose or weird. I know my AC is under the mattress in the back, so I’ll hit that tomorrow morning after coffee. Thanks again. I’ll post tomorrow with an update. 🙏. Kimmie
Whooooo hoooooo! It worked! I found the plug after folding my body upside down, and folding the back cushion up. I reset the outlet, and the wall unit is now on. Again, thank you so very very much! You saved my summer! And FYI, in the Tab320S, the plug is in the middle back. 😊😊😊😊😊
And @KimmieGuy - just an FYI. The Alde also has a plug, so you may want to secure it with some kind of zip tie to prevent it from becoming dislodged. That is always a good place to start with any Alde issues.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thank you again and again!!!! 🌈🌈🌈
- 916 Introductions
- 72 Teardrop Groups & Links
