2019 Tab 400
}}'18 320 S, pitched axle, 3020HE; PNW based
Denny16 said:
1. The Inverter is wired directly to the battery terminals, not the junction box, and has its own large cartridge fuse in line between inverter and battery.
Denny16 said:
2. The Power converter positive 12VDC buss connection is connected to the 12VDC at the battery switch, on load side, not the front 7-pin junction box, I believe, will verify this.
Denny16 said:
3. The Inverter has power control panel connected to it.
