I've owned and lived in my 2019 T@B400 for two and one half years. In that time I've replaced the following items, listed in order of failure. (edited to separate maintenance from premature failures and add photos)
1. Fridge fan (rear of fridge, after just a few months of use) Others on the forum have had this issue. I wanted a better fan so I did this at my expense.
2. Bathroom fan (replaced with fantastic fan) Many others on this forum have had this issue. I paid nuCamp to install better fan.
3. Maxxair fan motor & circuit board (within a week of installation by nuCamp after-factory, Maxxair provided replacement parts on warranty)
4. Water pump (twice, Pentair/Shurflo provided one pump on warranty)
5. Cool cat AC (whole unit, due to rust, Dometic did this on warranty)
6. Alde glycol convert to Rhomar (a couple of months after a Century flush) due to Alde system corrosion, at my expense.
Maintenance issues:
7. Kitchen faucet started leaking (the factory faucet isn't maintainable so I replaced it with one from Lowes)
8. Shower hot water valve started leaking (I tried Home Depot, Lowes and Ace for a replacement before contacting the dealer and nuCamp. They referred me to a supplier in Washington, Fisheries Supply, who BTW has great customer service. The valve took about a month to get)
9. Shower curtain lasted long, probably due to my use of soft water. Dealer/nuCamp shipped replacement quickly, with tax and shipping it was $150, ouch.
Rusted Coolcat AC covered by warranty:
Swollen Alde hose, looks like it's remedied with Rhomar switch:
Water heater
kitchen faucet valve replaced
maintenance of our 2 HVAC units
repaired roof shingles
replaced washing machine
I can imagine that my cost list is way above yours.
Our T@Bs are actually a pretty good deal. Makes me want to try full time.
But opinions are like belly buttons, some have more lint than others.....
Brad
Concord, NC
Southern California
Full-timer since 2019
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
Southern California
1. A water leak from the outside 120VAC outlet
2. Factory recall/replacement of the Green Core top floor layer with Azdel,sub floor added between the Green Core and new top Infinity Marine floor covering replacing the old one that had buckled.
3. Plugging the hole in the floor where the water tank filler and suction pipes come into the TaB under the wardrobe locker, which allowed a lot,of,dust into this area and the Alde compartment during the desert trip and subsequent dirt road journeys.
That is it. We changed the Alde fluid after 2.5 years, with Century a few months before the switch to Rhomar. No issues with the Alde or convector connections so far. Alde was run during the past winter while we had the TaB in our yard for the winter. Previous winter was spent in the shop having the floor replaced (no 2.). Warranty service from nüCamp was grand, and they even replaced the front window which had the internal scratch issue (a minor cosmetic issue). Previous owner kept the TaB in a barn during the winter, when not going to the desert, so Alde was not used much, only during damp cold damp days in the Pacific Northwest whilst camping.
Southern California
The 2018/2019 TaB floors are a composite layer Construction with a Greencore base, followed by a rubber membrane or sealer layer, with Azdel bonded on top. Then the rear bunk area framing is built on top the Azdel top layer, and fastened in place. See photo below of the rear area on a 2018/2019 TaB400 under construction:
If you look under your driver’s side rear bunk compartment where the Alde is you will see the dark gray or black Azdel floor layer. The Infinity flooring stopped at the front of the rear bunk under just behind the plywood panel. You can see the edge of the Infinity flooring coming out from under this divider panel in the photo above.
The finished top layer of Infinity deck covering (this is a marine grade deck and cabin sole covering material, and is completely waterproof and stain resistant) goes from the front to the bunk front partition panel only. Infinity Flooring has a soft feel to it when walked on as it has a slight padded backing under it. It is designed to be walked on barefoot or with soft deck shoes, not hard sole street shoes. We go stocking or barefoot inside the TaB, and like this soft feel. The composite floor it self is not soft.
This is he finished repair after everything is put back:
There isn’t any practical way to get the new Azdel layer and Infinity floor covering under all the cabinets or wardrobe/washroom area, and isn’t really necessary, as this area is not exposed or walked on, and remains undamaged.
The problem was only in the area where it was walked on.
Southern California
2013 Tundra TRD 5.7L
Massachusetts
Southern California
