First, the important bits up front:
So, we "driveway camped" at a friends house last night, and took advantage of their hose to start flushing our camper for our big trip in July. Which is where some of our questions / issues came up...
First, despite running a LOT of water through it, the kitchen sink would always give "foamy" water when first turned on, but no "pink" antifreeze. When we first turned on the water, it was pink, which was expected. But what's with the foam?
Second, if you don't have the Alde turned on to provide heat / hot water, will water still run through the hot lines so you can flush them? Looking through the plumbing resources here, it looks like I should've turned the red handle to bypass the hot water tank.
So, we did have one issue and hopefully we can get it resolved before our upcoming July 4 trip. When we picked up the camper, the hot water braided hose to the kitchen sink was twisted. The walk-through tech fixed it (presumably removed it, untwisted it, re-attached) Well, it leaks. Not bad, but enough we had to take a towel to under the sink. I think it did this because the braided hose from the faucet to the Pex line still has a "crimp" in it (like you get when you "crimp" a garden hose to stop the water) and it's bumping up the pressure and coming through the fitting. We're going to call our dealer about it tomorrow, and with my work schedule I can get it over to them soon.
Other than that, everything went well (hey, we were in a friends driveway!)
Next I would turn the Red Alde bypass valve to horizontal position, agin whi.st connected to City Water, fill the hot water and Flo tanks, leaving the hot water tap,in the galley about 1/4 way on, to get water flowing through these tanks, and make sure they didn’t get any antifreeze in them. Run water until all is clear.
Are you sure the faucet aerator is not just being super active?
Hot Water Pipes (lines)
If the Nautilus Levers are set for 'City Water , Winter Mode' {the Alde in by-pass} your hot water pipes will be flushed with new/clean/cold water. If the Nautilus Levers are set for 'City Water' normal mode the hot water pipes and the Alde tank will be flushed with new/clean/cold water.
Side Note: If the trailer was correctly winterized.
The Adle tank would be empty - no pink antifreeze - as Alde guidelines are to not put
the anti-freeze solution into the Alde.
If you would like additional information on the Nautilus settings including graphics showing how the water is flowing take a look at the forum resources section - -
We're going to bring the camper out to the house (obviously) before our July trip, I plan to re-flush the lines then. Plus, I'm pretty sure we've got better water pressure than our friend does, so even with the pressure regulator on the line, we might get a bit more "push." (And we did have the regulator on our friends' hose as well, I do NOT want to blow out my water lines!)
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
My experience with RV Water System Antifreeze in two boats and the T@B 320S is that 'it' does not cause that much foaming - - - while even in very low concentrations 'it' does effect taste and under the right lighting color.
P.S. As @Denny16 noted you must also flush the shower(s) and toilet to get all the anti-freeze out of the system.
(OK, and yes, I was hoping my comment would jog someones' memory and they'd recall the topic and point me to it!)
Jay and Kat
The trick now being, flushing the hot water side, when we've got a leaking connection under the kitchen sink. Probably put a bucket under there (it's a slow drip when there's water coming through) and use my hands to keep the hose open so the water flows (already scheduled a drop-off at the dealer to get it fixed.)
Jay and Kat
What we're planning to do, and maybe you can comment on if it's safe(ish) or not, is still fill the fresh tank, so we can use the bath, and just not use the kitchen sink at all. I'll still work to flush the kitchen lines, and might even go further to avoid leaking by capping the end of the water line that's the problem.
Thankfully, the leak is a slow drip from where the braided steel line from the faucet connects to the fitting on the end of the pex water line from the hot water tank, so I should be able to get a cap at a hardware store. And, by disconnecting the braided line, I can flush that line (into a bucket) as well.
Or at least, that's my thinking...
Jay and Kat
What I think is partially responsible for the leak, is there's kink in the braided line from when it was severely twisted (when we picked it up.) Lets see if I can attach the picture of the kink (OK, it's the circled bit) I've tried (by hand) unkinking it, but as soon as I let go, it kinks again. My thinking is, the kink increases the water pressure going to the faucet hot side, so when the water's on, the pressure needs to release and is able to work through between the threads and out (or maybe out the "top" of the braided line fitting, where it allows the nut to turn)
Jay and Kat
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Worst case if we can't cap the end of the line off to prevent a leak, we don't use the camper plumbing on our trip, the campground has facilities we can use.
Jay and Kat
And, I'll take advantage of having the faucet disconnected initially, with a 5-gal bucket underneath (or a 1-gal, if the 5 doesn't fit) to flush that line out.
Jay and Kat
Jay and Kat
