2022 Nucamp Tab Air8 error Code EO1
On my way to Alaska, I will be entering on Canada Sunday so not close to a dealer . 92 today and I have no air. Getting Error code E01. Used the reset number for fan 8699 as explained and followed directions and now get -9.9. Bummer just starting my trip 5 days in. Any help would be greatly appreciated. FYI, air never worked.
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
  • Yoshi_TABYoshi_TAB Member Posts: 514
    HI,  Here is the email for Elwell if you don't get an answer or work it out.  I have emailed them a bunch of times with questions.  Pretty good response time, but with the weekend, it may take a bit more time.  Good luck
    jwelwell@elwellcorp.com
    2025 360 CS
    Southern Maryland
  • MuttonChopsMuttonChops Member Posts: 1,805
    homerd said:
    . . .  no air. Getting Error code E01.
    . . . Used the reset number for fan 8699 as explained and followed directions and now get -9.9.
    . . . FYI, air never worked.
    Just some WAG suggestions while you wait on Elwell to respond.
    1)  Have you seen the thread:
          https://tab-rv.vanillacommunity.com/discussion/11277/air8-reprogram-for-continuous-fan
          Above thread suggests First running Air8 in Fan Only Mode before selecting Cooling Mode
    2)  If FAN did not get reset to Continuous Mode, you might try resetting it a second time.
    3)  Since ERROR 1 is a "(cabin) Return Air Sensor Failure:
         -  Pop cover on Air8 and confirm all wire connectors are well seated
         -  Confirm any user access Filters are clean
         -  Confirm nothing is blocking the cabin air return flow into the Air8 space
             or jammed against the cabin air input side.
