Our first trip with a loaded up camper is coming next weekend and I've seen recommendations to take your tow vehicle and camper to a scale (CAT scales often mentioned) to get your weights before heading out on the road. How vital is this?
My TV is a Jeep Gladiator w/Tow package, so up to a 6000lb trailer weight / 600lb tongue weight, the camper is a '22 T@B 400 Boondock w/3-way fridge so probably just over 3000lb dry weight / 315-ish tongue weight dry. Figure a full water tank will add around 340-400lbs (depending on conditions) and from what people here have said, that tank is pretty much centered over the axle, so it'll increase the tongue weight, but not horribly. Add in everything else in the camper, make sure I'm still within the max capacity of the Jeep, and I'm thinking it'd take a LOT to overload me.
Now, I do have, and plan to use, a tongue scale before we head out, and that's where I could see the advantage of knowing the weight of the camper (loaded,) because the rule-of-thumb seems to be the tongue weight should be about 10% of the total weight of the camper for safety.
I guess where I'm going with this, am I risking life and limb if I don't take the rig to a scale?
Tow vehicle: 2022 Jeep Gladiator Sport S w/tow package
Camper: 2022 T@B 400 Boondock w/3way fridge
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
0 ·
It’s definitely useful to know the overall weight though, because unless you weighed every single item as you packed, you really are just guessing. Most people find their trailers are heavier than they guessed, sometimes by a lot.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2020 Tacoma TRD Off-Road
The only time I really paid attention to the numbers was pulling a trailer rated at 7200 lbs with a half-ton truck.
https://tab-rv.vanillacommunity.com/discussion/9115/2020-t-b-400-fresh-water-capacity-change/p1
Jay and Kat
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
CAT Scale locations come in two types. Newer installations have three pads so it is possible for most longer wheelbase tow vehicle [TV] to position your rig so one pad reads the Front axle, second gets the Rear axle, and third has the trailer axle. Older CAT Scale locations only have two pads. On those you end of with the TV on one pad and trailer on the other.
I've scaled my 320S twice.
The first was on a three-pad-scale with my TV & T@B fully loaded for a standard boondocking trip.
The second was on a two-pad-scale. I was in the process of starting a self-move using the TV and TaB as my 'moving van' . . . it only took 6+ cross state trips
