Can't speak for your specific model, but I used several super long zipties to secure mine underneath the trailer tongue and frame of my 400. I check them periodically for wear and tear but so far going strong.
--Marlee 2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
Thanks very much for the info. I ended up using 3x adjustable black rubber tarp tie downs and using the upper screw hole in the hose carrier near the hitch to mount it into the frame. I was nervous to use the upper screw hole near the step because the frame was covered by the under belly.
