We just returned from our 1st camping trip and were wondering if we should add some sort of Black Tank Deodorizer since our next trip isn't planned for quite a while? We only used the toilet for clear deposits and no toilet paper. We emptied the Black Tank at a dump station and followed up with a Black Tank flushing of water until the water was clear. Any advice is greatly appreciated.
Thanks,
B
2022 T@b 400bd
2022 F-150
Gratitude
0 ·
FYI, I also empty the fresh water tank (by opening the release valve usually at the dump station) as well as the Alde system. You need to access the driver side bunk compartment and release the yellow valve to drain. This eliminates the opportunity for bacteria to grow in stagnant water.
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
I had no idea the Alde system needed to be emptied! Is it water that is emptied? I know the Alde system has glycol and we don't want to empty that since our camper is new and that doesn't need to be changed for a couple of years(I think).
2022 F-150
Gratitude
You might consider "Happy Camper" for tank treatment if you don't have some already. Dry powder - add a scoop and a gallon of water, flush. Ez pz. Highly recommended by many, and I have been happy with it too. Available at Amazon and other sources, I am sure.
Is there a lower drain on the outside of the camper that must be opened as well once I have opened the "yellow valve" inside the camper? I know where the Fresh Water drain valve is located behind the driver-side backend of the camper. Would the Alde water valve be located near that?
2022 F-150
Gratitude
I reread the Alde manual and the Nautilus Manual and didn't find anything re this??
I also did a word search on the 71-page Tab 400 manual. Again, nothing.
Honestly, I'm finding the manuals for the T@b 400 are lacking compared to what I had with my Winnebago Class C RV.
I couldn't locate any specs re the tanks in any of the manuals. I found them online and in our little brochure. I would expect that a manual would have all the technical specs and capacities for the camper. Nope! Nothing. Very odd.
2022 F-150
Gratitude
And welcome to the family!
2022 F-150
Gratitude
Love this forum.
Just want to be clear that by opening the low point drains, none of the water from the hot water faucet that was opened in the camper will drain into the Gray Tank?
2022 F-150
Gratitude
