Some co-workers today made a comment about towing with a fridge running on 12V and stops, suggesting not to do this as it'll drain the tow vehicles battery. Well, we're heading north with a 4-5hr drive (said time includes a stop for breakfast) and I'm wondering if when we stop we should either disconnect the camper from the TV while we eat, or go in the camper and turn off the fridge so we don't have to ask for a jump start to get back on the road.
Or, once again, am I over-thinking things and the camper batteries and the solar will be more than enough to keep the fridge running without draining my Jeeps battery while we have breakfast?
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
0 ·
1hr wait for a table, 1.5hrs to get the meal...
Nah, wouldn't be that bad, (I hope) probably an hour-ish or so. But it sounds like if it looks like it might take "a while" we'd be safer either shutting the fridge off while we're there or disconnecting the camper from the TV electric.
Jay and Kat
And I think I'll also give that electrical test a try when we hitch up tomorrow to bring it home.
Jay and Kat
Our campsite will have a 30A shore hookup, which would be running the fridge on-site.
Jay and Kat
As we travel down the road we check occasionally check the battery level with our Victron battery app. This is convenient and if I see the battery get into the mid to low 80% range I will turn off the fridge at a gas stop or lunch break, drive for a while to recharge the battery then turn in on again. On long trips, say 7-10 hours of driving I will usually turn the fridge off and back on a few times just to be safe. When we stop for an extended break, lunch or whatever, I will also turn it off as I do not feel the performance of the 12v power is worth the draw down on the battery. Keep the fridge closed during your trip and keep an eye on your battery and you'll be fine. But on long stops I'd turn it off. If all is cold inside it will maintain cold temps for a while. Or if it's gonna be a few hours of stopping you can always turn on the propane during your stop.
Some recommendations:
- Freeze multiple smaller bottles or ice packs, put them in the pre-chilled fridge along with your pre-chilled food. The fridge makes an excellent cooler.
- I’ve seen a couple of people recommend alternating the fridge on or off for every hour or so of driving if you’re dealing with a long drive. In other words, stop to stretch your legs every hour, and switch the fridge on 12v from on to off (or vice versa) when you do so. While this does use a fair bit of power still, it’s half what it could use if you simply left it on. Since in this case, you’ll have power when you arrive, if you want to try this, I’d probably only run it for an hour in the middle of your drive; it will stay plenty cold in between for a couple hours if you have some ice packs in there too.
- Two items you should always have in your Jeep: a 12v tire inflator, and a self contained battery pack capable of jumping your own battery. Especially on a holiday weekend, when roadside assistance will take absolutely forever!
How you go, depends on the drive time, and outside temps. For longer drives, you could run the fridge on DC for n hour or so, every three hours, and the Jeep should maintain the charge driving with the fridge off for two or more hours.
It is very situational, and there are too many variables for any hard and fast rule or approach.
Southern Maryland
The '22 Gladiator Sport doesn't have one.
The camper is at home now, in AC with ice jugs in it and a remote thermometer, so we'll see if it cools down, considering I had to put it in the drive with the vents for the fridge facing the sun and it's touching 90F already outside...
Jay and Kat
Jay and Kat
As an aside, just did a 5 week trip through the Pacific Northwest, and was very impressed with the 12V Isotherm in my '21 T@B 400. Kept frozen stuff frozen on the #5 setting, and had enough room for (just) me. I was concerned about the parasitic draw on the TV battery ('13 F150), but on a couple occasions I left it hooked up/plugged in overnight while off-grid, and didn't notice any issues when starting the truck in the morning. Since I wasn't measuring battery voltages or draw with the engine off, those results don't really mean much.
Is it confirmed that the trailer battery charging function on the 7-pin connector will allow the TV battery to be drained? I'd think the charge controller wouldn't let that happen.
Trips - 48 Mileage - 63,452
