Shower Walls?
4th season down, including 3 straight months, and no issues. I also squeegee down the walls.
2 -
@gbell - what kind of caulk did you use to re-caulk the space between shower base and wall?gbell said:We just recaulked the shower base where it meets the wall. Some caulking was coming off and water was able to drip down the wall and slide to under the shower. Not much but enough to recaulked it. Easy to fix.
@VentureOut @gbell has not been active on the forum since March 2021. It is unlikely you will get an immediate answer. Perhaps a DM will prompt a response. -Denise2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0
- 424 Service/Maintenance & Recall Notices
