drain fitting in fold down bathroom sink ( 2019 T@B400 model)
peterjoce400
peterjoce400 Member Posts: 51
due to inadvertently unscrewing the plastic drain in the bathroom sink, the fitting in the base has disappeared somewhere inside the sink.  Has anyone successfully taken the sink apart ( seperated the two plastic pieces that form the sink)?  Also will be removing the single lever faucet and replacing it due to internal corrosion grinding shavings when the faucet is raised or lowered and I suspect will at some stage have to remove the entire sink and back plate from the wall but that will be a later project.  Update:  you cannot split the top and bottom of the sink apart.  After removing sink fish the disconnected bottom fitting back up into the drain and screw the top fitting back down.  Easier said than done, but with a whole load of patience and persistence worked for us. Changing the faucets over from kitchen to bathroom and installing new style of folding faucet(all metal no plastic) on kitchen sink is straightforward (but still necessitates removal of the bathroom sink first).
Hans Peter,  Nanaimo, Vancouver Island
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
