On our 2014, and probably on your 2013 too, Jimbo, the overflow is not on the filler fitting, but a tube comes out in the middle front, under the trailer. You can hear it dribbling when it gets full.PXLated said:Yep - there's a little overflow/vent right above the filler tube that will start spitting water as well as the main filler tube - at that point, you're full.
Same on my early 2015.ChanW said:On our 2014, and probably on your 2013 too, Jimbo, the overflow is not on the filler fitting, but a tube comes out in the middle front, under the trailer. You can hear it dribbling when it gets full.PXLated said:Yep - there's a little overflow/vent right above the filler tube that will start spitting water as well as the main filler tube - at that point, you're full.
In fact, on ours, that little vent hole above the filler tube was not connected to anything, and allowed water to seep into the wall cavity behind the filler. You might want to check that.
Deltaboy59 said:Try this...works every time... No drip no mess...
6 bucks for hose at wal mart
screw into spigot hole on water jug
leave it on for future use
use other half of your cut hose to screw on your fresh water hose when using it to fill your tank
ericnliz said:@dsatwork, While you're at Wally World, look for the siphon pump that takes 2 "D" cell batteries. Long enough hose to reach, no adapter required. Go on-line to Walmart.....type in siphon pump, it's the one listed as "Fashion Automatic Electric Fuel Fluid Water Siphon Pump". Works like a champ...cost..$10.79.
It will fit in the 5 gallon cubes I have, but those take up so much room in the tow vehicle and the 6 gallon desert patrol style Reliance tanks can just get stuffed anywhere if they are empty. I may just be adding water to the fresh tank manually again on this trip. But these Tab's are so particular and it seems that using the 6 gallon desert patrol style Reliance tanks and jamming the 3/4" nozzle into the fill hole created air bubbles that the under powered pump couldn't pull through. Arrrg I'm hoping that all the stuff that was inside my fresh water tank is out now and the pump won't be as temperamental. Do you hear the frustration in my voice? I'm actually taking a replacement pump with me on this trip and I'm hoping I won't have to waste my time installing while I'm on the road.
) your friend! Just gotta watch for the "tipping" factor on the container when it starts to drain.
Agree with dsatwork, can you post up some photos???visher said:I hate hoisting a 5 gallon water jug up to pour into the fresh water tank as well. Siphon works if you put it on the propane tank cover but that is too weak to support the weight safely. I installed a small 12 volt water pump under the T@B with intake and discharge tubes stored next to propane tank.
I haul the five gallon jug from the campground spigot and place it next to the trailer then drop the intake hose into the jug, the discharge into the fill hatch, flip a switch and fill up. No interior plumbing required. This system has worked for about 4 months total on the road and I am very happy with it.
