Dometic air
My air keeps cutting on and off anyone had this problem? What should my settings be?
  • cafyrman
    cafyrman Member Posts: 40
    I had that issue when one of my vents was pointed directly at the thermostat.  As soon as cool air started coming out, the thermostat would sense the cooler temp and shut down.
    2018 T@B 400
  • Denny16
    Denny16 Member Posts: 5,431
    edited July 2022
    I am assuming you have a DometicCoolCat AC.  You can also change the fan from Auto to continuous fan mode, so only the compressor will cycle as needed.  This helps to distribute the cold air better between cycles.  In a hot temp situation, I think continuous fan works better than Auto fan mode.
  • hikerchick
    hikerchick Member Posts: 35
    I have it on low fan and set to 80 degrees and it doesn’t stop I am cold
    MuttonChops Member Posts: 1,977
    My air keeps cutting on and off anyone had this problem?  . . .
    TaB Model?   TaB Year?    A/C type/brand?
  • hikerchick
    I called the dealership they said to take it off auto and this seemed to work. But now I’m home and left the air on so I could clean it and now I have it on 78 but it doesn’t seem to want to stop running. My Tab is 400 2022.
  • hikerchick
    I was told I should leave the windows in the middle slot that it should be vented is this true maybe this is my problem.?
  • Denny16
    The CoolCat AC recirculates the air in the TaB.  If you are camping, you need a source of fresh air and exhaust the CO2 you exhale.  I leave either the front window or rear window in vent mode and slightly open the roof vent.  This insures you get rid of old stale air and have some fresh air added to,the trailer.
