I have a 2019 320CS and starting this year the Jensen volume knob turns but doesn't do anything. I can't change the clock (have to use the volume knob to change the clock) or change volume. The remote also doesn't do anything. I tested the remote battery and it's fine. I also tried the reset button a number of times. The reviews online for Jensen radios are pretty poor and I'm wondering if anybody else has had a similar problem. With the Jensen dead I can't reset the clock, play DVD's, change the volume. Any thoughts?
0 ·
this Jensen model does support their bluetooth app. {I've never used it so can't help with that}
My 2018 build has the same Jensen unit and it also has Volume Knob problems. If I just turn the knob nothing happens. However, pressing down (toward the floor) or up (toward the ceiling) while rotating the knob does cause changes to the clock or volume values. At some point this work around will also fail but for now it works.
With my remote I've found it works best if I start by using the remote to Power-on the Jensen. If the Jensen is already on and I've touched any of its front panel controls then the remote most of the time won't work. Weird, crazy I know but seems to be the case.
2023 T@B 320 S Boondock
