Hello All! I accidentally damaged one of the BAL stabilizers. I’ve ordered a new one (same model/brand) but am having a hard time removing the old one. It appears that the factory didn’t install them as per the BAL instruction manual, i.e self-threaded bolts. The bolts are installed in the opposite direction and the nuts/washer is accessible…. Onto my issue…. I have successfully removed 1 nut/washer but on the other 2 the bolt turns with the nut. It doesn’t look very accessible from the inside flooring of the trailer so I am wondering how the bolts are installed. From the inside of the trailer, through the floor? Or tack wielded to the frame mounting plate? I am pretty capable in the repair department and don’t really want to bring it to the service center. Thanks in advance, Brian
1 ·
Trips - 48 Mileage - 63,452
