Jenson wall stereo playing thru television speaker and wall speakers
nettlesnettles Member Posts: 30
I only want sound from the wall speakers.  How do I turn off the sound coming from the tv speaker?  (I haven't a clue how I turned it on!). 2018 320s
2018 T@B 320s, 2013 Toyota Highlander
    @nettles go to tv menu, select audio, manuever down to tv speaker and push left or right arrow button to toggle tv speaker off.
  • MuttonChopsMuttonChops Member Posts: 1,909
    @nettles;     A second option to the one @dragonsdofly provided is to:
      -=-  Select 'TV' on the TV remote
      -=-  Then use the remote Vol- to lower TV speaker volume to zero
               this method is handy if at times you do wish to have the TV Speakers on
               as I sometimes do to watch/hear a local news cast.
      -=-  After setting TV speakers to zero,
              Select 'VCR' on the TV remote; now the remote vol-/vol+ will adjust
              the Jensen wall speakers . . . you will notice different style "volume settings"
              displayed on the TV between the two sound adjustments.
  • nettlesnettles Member Posts: 30
    Thanks for the suggestions.  So many things to figure out.  I 'm taking a break today.
    @MuttonChops, that is a cool tip for controlling the Jenson stero volume with the TC remote.  Thanks.
