Hi All!
i just bought a 2022 Tab a month ago and had my shakedown cruise over the weekend. All seems to be ok except for the stove, which isn’t lighting. I think the gas flow is fine because the hot water is great and set on gas only. i tried a lighter to see if there is any airflow at all and i didn’t see any, and no smell either. I held the button down on “lite” for awhile to get any air bubbles out. i also turned the gas off then on again to about 1/3 open to see if some sort of auto shutoff gas leak thing was stopping the gas. i read about that. But it didn’t help.
i have called the dealership but i was wondering if anyone had a suggestion about a switch or something that i could try. No suggestion is too obvious since I know almost nothing.
Thanks!
2022 T@B-S
2023 RAV4 Prime
Central BC
0 ·
TV 2025 Telluride X Type
Typically the dealer does a walk through when a trailer gets picked up. Did you get one and did the stove work ? As already mentioned try opening the propane tank slowly, also check if there's propane left in the tank. I had a tank leaking once.
Grumpy_G I was not connected to power and I had the Alde power setting on gas, with the electric source turned off. They did a walk through but I dont think they actually turned the stove on during it.
Freespirit I will try that, but i will be a bit sad if this is the long term solution. The bugs will eat me alive!
Elbolillo Do you mean unhitching the gas tank right at the tank?
2023 RAV4 Prime
Central BC
2022 T@b 320 S / 2021 Subaru Outback
My unit is the S model, not the clamshell.
I live at about 2000 feet and went up to about 3300 feet for this trip. I dont think that would make a difference would it? Mind you, it was sold to me at about sea level and presumably the techs at the dealership confirmed that the stove was working when the unit arrived there. I would hope so anyway?!?
Thanks again for the advice everyone. I have an appointment with a local rv dealership but of course that isn’t for almost a month….but if i have any luck before then i will let you know.
PS: I tried turning the tank off and then turning it on again very slowly and that didn’t work.
2023 RAV4 Prime
Central BC
The RV service people would like the serial number of the stove to do some digging before they see it. Does anyone know how to get the serial number? It isn’t stamped anywhere visible on the stove so would probably have to start unscrewing the top. I will check with nucamp technicians but if anyone happens to know?
Again, thanks for all the advice!
2023 RAV4 Prime
Central BC
