No water on a T@B 400
amelia
Member Posts: 4
Right now I am connected to city water (and there is water coming out of the spigot, I checked) but I am not getting any water coming out of any of my faucets. I can get water out of my fresh water tank, but nothing from my city connection. Any ideas what could be the problem?
Dumb question, but are you positive you have the four valves in the "city water" position on your nautilus panel?
What year 400 do you have? That info will help our experts here help you.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota -
If your TaB has the Nautilus P3 System than as @marleecamps suggested confirm your Water Management System 'Colored' Lever Positions are correct for City Water:
Additional information can be found in the Plumbing Resources Section of this forum'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
@amelia, what year is your TaB400/ok a 2021, so you have a Nautilus water control panel on the driver’s side of the TaB towards the rear. These are the valves muttonchops was referring to. You need to set it to the City Water position as shown on the diagram on the panel. It seems you have it on Dry Camp positions, which gets water from the TaB’s water tank, but not from the city water connection.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Amelia has a 2021 400.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks Sharon, then she has the Nautilus system, modified my post to reflect this.
- 916 Introductions
- 72 Teardrop Groups & Links
