Cleaning up the T@B after a 4-day trip and just happened to see a lot of bright sunlight around screen door. Looking closer there is a rather large gap, 3/16" or so between the screen door mounting bracket and door frame. No wonder we had a lot of bugs in camper! Really seems like there needs to be a gasket between the frame and opening, is it just missing from mine or is the "normal"? The camper was built in Nov 2021 and came with the door already installed.
I have gaps all the way around. If there is supposed to be a gasket there (i.e., are there T@Bs that have it?) then I would hit up the dealer for the product. It is an easy fix, but would like to hold them accountable.
South Jersey
Last month I finally got the screen door and I installed it myself. I noticed a gap exactly like yours - and a smaller one on the kitchen side of the door. I thought I might have missed something - some secret way they fit the door perfectly. Apparently they don't. Makes me feel better, but I'm definitely looking for some good ideas for covering these gaps. For now, I showed some weather stripping in there, but it's not the prettiest.
If I assume I have an average of 1/8" gap (that is conservative, most of it is wider) around both sides (75" tall) and top (25" wide), that is equivalent to a 1/8" x (25"+2x75") = 21-7/8" area which is like having a 2-1/2" hole in my screen.
I had a bag of open cell foam laying around and by using a putty knife I compressed it and filled the gap. I did not use the PSA since this is a temporary fix, I'm heading out on the road again in a few days so this should work for now. At some point I will remove the door and put a decent gasket in there which will not be so visually apparent.
The foam I used is Frostking, fills gaps to 3/8", actually worked pretty good.
South Jersey
On a side note. The screen door frame was a VERY tight fit at the top - still working on how I can get the corner covers on since they make the frame slightly wider and it's already pressed against the sides without them on.
