More and more, I move things from the tv to the bunk of the 400. So far no change in towing characteristics ( tv is a Subaru Ascent). From empty trailer wt to gross wt is about 700 lbs, maybe more. I guess it is theoretically possible to move that much stuff from the tv to the trailer. My sense is a lighter tv will be closer to being level and the tongue wt will be less. What are others doing in this regard ?
400 - 2019
St Catharines, ON
0 ·
The safest way to level a tow vehicle is with a weight distribution hitch, tried and true for some 70 years. I think Safeway makes one that will fit the Tab 400 and its frame size. Level your tow vehicle, restore the normal weight on its front axle for normal steering, braking and sway resistance, and you get built-in sway control as a bonus.
Remember that heavy items carried behind the tow vehicle rear axle and toward the rear leverages the tow vehicle toward sag at the rear. Try to load there heaviest gear forward in the tow vehicle, and lightest gear at the rear. That helps as well, and decreases necessary tension on the weight distribution hitch spring bars.
Air bags are often mentioned as a cure, but they only level the tow vehicle, they do not restore normal weight on the tow vehicle front axle.
Doug
Minnesota and Arizona
Additionally, it can help if you move the heaviest part of your tow vehicle cargo forward of the car’s rear axle. I do this when packing my Outback, dropping the rear seats down and putting the heavy stuff close to the front. Which, yeah, means I have to access it from the side doors rather than the hatch, but between that and rebalancing the trailer to the correct ratio, sag is minimal. I also work hard to keep my load as light as possible in both trailer and tow vehicle, and obviously that means I’ll see less sag than someone with the exact same setup + more gear. It’s worth seeing if you’re carrying non-emergency stuff out of habit that never gets used.
@kottum suggested an WDH. These are absolutely NOT allowed with the Ascent, as stated in the owner’s manual. It’s a great way to crack the unibody construction of your vehicle.
St Catharines, ON
All that said, I’ll go back to what I said before. Subaru uses very soft rear springs on both the Outback and Ascent. It doesn’t take much to compress them, mine went down a bit just switching from a donut spare to the full size spare required for AWD towing, maybe a 40 pound difference at most. If your main issue is sag, I would doubt you can safely get the 400 lb+ 2019 400 tongue weight low enough to cause the Ascent to ride even close to level. If you are below both your payload and tongue weight limits when normally loaded, the smartest option is to simply replace or supplement those springs.
Heavier springs or air bags will not help because the heavy load will still be on the tow vehicle rear axle and the front axle may be too light for safe steering, braking, and sway resistance. They just lift the rear up so the headlights are normal.
If you put the heavy gear in the rear of the Tab trying to lighten the hitch weight, you are going against the safe loading procedure for the trailer, causing it to be less stable.
So I think the answer lies in carrying less heavy gear or getting a more capable tow vehicle.
It would be interesting to weigh your loaded rig at a truck scale and see if you are pushing the load limit for the Subaru's rear axle, and see how much load you are removing from the steering axle. That could be another problem. I don't know the weight of your gear or the limits of the Subaru axles, or how the axles are loaded. A trip to the truck scale would help determine your actual three axle loads. Then decide if you carrying capacity is okay, where the loads need to be placed (without screwing up the balance of the trailer), or if you need to leave some gear at home.
Doug
Moving a heavy load high on the tow vehicle (or trailer) will decrease the lateral stability of the tow vehicle, and may greatly decrease the braking ability as the load is shifted to the front axle and taken off the rear axle when brakes are applied.
Doug
