Just curious if anyone has removed this back panel to clean behind it? As you can see, debris has collected between the panel and the body of the trailer. In fact, enough debris that small mushrooms grow in the winter! I suppose I could just power wash it out as it appears water is designed to run behind this panel and drain out. Any recommendations would be appreciated. Cheers!
Based on Factory Build Pictures and inspection of my 2018 model-year 320S there is no structural support/panel/wall behind the Rear Plastic Cover. I suspect if it was removed getting the cover back on and fully water sealed would be a major task.
The Rear Plastic Cover fills/covers a gap between the Aluminum Roof and the trailer floor.
Adventures: 58 Nights: 405 Towing Miles 50,180
2020 Tacoma TRD Off-Road
New unknown material at rear of 320S . . . .
No sunset red glow in a 400 as there is not metal to block the light . . .
