I went through this last year when the trailer was new to us, There is a long post about it, and about the wiring diagram for the dc wires at the unit on the back of the fridge.
2018 T@B 400, no solar, 2 way fridge AC-DC...
Essentially I found that if I leave the battery switch in the cargo area ON, then plug into my shore power (with or without surge protector) the fridge stops cooling, fridge light still works.
After much effort to check what I could, I know that the DC power is good all the way through the fridge plug and to the unit on the fridge. Mysteriously the fridge would start working again after sometime.
This happened a couple more times until I realized the transition on or off of shore power was triggering it.
I started to always turn battery switch off when plugging or unplugging (probably a good idea anyway) and the fridge ran without trouble this way, until I forgot my method and plugged in this morning.
(I am in the midst of driveway testing my battery under dry camp conditions, another post I have going)
The fridge wont cool again even after pulling it out (pain) and test continuity and DCV.
I was thinking the control unit on the fridge has some built in surge protection of something, but it doesn't seem to be resetting this time.
I may be the only person this has happened to, but any Norcold 2-way experts out there?
Fuse good obviously
Puzzled and bummed in Ohio
0 ·
After typing that post and about 15 min I checked again and it is cooling.
All I can figure is there is a surge even when unplugging shore power coming from the converter panel or as the fridge unit itself senses AC drop and switches to AC. Its 7 years old so I reckon I will just have to treat it like my 15 yr old rescue dog. Gently.
Still love to here from anyone who experienced this type of fridge issue or who understands that fridge control unit.
Not sure what is going on with your Norcold, we have the same fridge in our 2018 TaB400, never had this issue following the procedure I outlined above.
It must temporarily protect itself electronically.
I have to remember this for the portable solar as well, they say hooking up the panels to control before hooking to the battery can cause damage.
I did accidentally unplug the battery first while repositioning the panels but i rushed over to fix it, seems ok...
Headed back over to my battery discussion this eve, its running the fan and fridge today without solar.
Learning a lot!
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
After a 3 day lakeside stay plugged in I brought the trailer home and left it on battery power in driveway. The fridge ran for another 36 hours that way.
Using the above method of turning off the battery cut-off switch, turning off the breaker in garage then hooking up the power cords and surge protector then turned breaker back on AND...???
The fridge stopped cooling again. cranking up the setting knob wont get it to run. The blue light comes on after a delay when the door is opened, but no compressor activity.
the propane detector was flashing its red light (next to the propane labeling)..
I spent a few hours messing with the satellite dish on our house (almost got it aligned, ha)
Went to check on the trailer and the fridge is running and the propane detector is back to green light status.
The fridge is set to coldest temp and clearly has started cooling only recently, and the blue light comes on instantly upon opening door.
There is an unusual set of symptoms to ponder on the forum.
Battery cut-off switch? AC/DC converter?
Reckon I better check the wiring schematic, but the fridge has its own fuse for DC power, Maybe the propane detector trouble indicates a voltage issue.
20amp circuit in garage pretty much dedicated to trailer
The one labeled fridge does what you would expect, fridge powers on.
But the one labeled converter exterior kitchen also cause power to reach fridge.
It is all very puzzling, especially the delay in the blue light that comes and goes, and the cooling failure on AC and DC (though I understand even on shore power the fridge itself converts to DC).
Hate to replace it if it could be repaired. It gets cold enough to freeze a jug of tea when it does work.
I will provide some general side line observer comments
First. The Model 400 has changed a lot since the initial 2018 release. @Aubrey 2-way Fridge is not running only on 12VDC as the more recent build years. Both his Control Model Wiring picture from last year and his recent comments on the effect of tripping WFCO Power Center AC Breakers supports this, his 400 has both 120VAC & 12VDC supplied to the Fridge.
attached PDF file has full diagram
Second. I fully agree with others that Turning Off All Trailer Appliances is the very Best Practice before switching from Battery Only to Shore Power. And at least switching the WFCO Main Breaker Off if an RV Park Pedestal breaker is not available should be included.
However, having to disconnect the Battery is not standard. If that is really the only way to avoid Fridge restart issues . . . it seems something else is wrong with the Fridge components.
Third. Could all of @Aubrey issues be related to a poor production quality thermostat ?
Fourth. The nr740 does have thermal interlocks and while not normal, weird power surges due to not having everything off during Battery to Shore Power changes could be confusing it {most likely because that circuit is already weak}.
The nr740 manual referenced by @Denny16 last year includes a simple LED Troubleshooting Lamp diagram (build instructions) and Thermal cutout is Error Light Flash Code 5 (see PDF).
Believe that's it for my observations.
Adventures: 51 Nights: 322 Towing Miles 41,200+
The wiring from the camper converter is a lot harder to access.
It can produce cold temps when it decides to turn the compressor on.
Norcold NR751BB
Of course, all that is moot if you actually have the 110 line to the fridge and that line is working.
I turned the converter breakers off, hooked up to shore, turned on garage power, knelt in front of the running fridge and flipped on the main breaker then the fridge breaker.
It switched to shore power seamlessly.
Ordered a thermostat from online seller (kind of hard to find?)
Part number 635832
Maybe I should have done this last year when the thing acted up?
HA!!! Lets hope they actually have one to ship. I will update between the 7th and 12th
