ALDE bypass valve question
We're planning on winterizing soon, I know the general WHERE for the bypass valve (T@B 400 Boondock) under the bed on the drivers side.
Would anyone have a photo to show exactly which valve it is?  I *THINK* I can find it, but paranoia has me trying to verify first...
Jay and Kat
Tow vehicle:  2022 Jeep Gladiator Sport S + tow package
Camper:  2022 T@B 400 Boondock w/Norcold 3-way fridge
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,017
    You have the Nautilus.  There is no separate Alde bypass valve.  That only applies to the pre-Nautilus models.  Just follow the Nautilus guide for winterization or this:
    https://tab-rv.vanillacommunity.com/discussion/14611/procedure-to-winterize-via-air-compressor-t-b-400-with-nautilus
    edited August 2022
    As @Sharon_is_SAM said just follow the instructions and you'll be fine.  The Alde bypass lever on the Nautilus is not marked as a bypass valve as they  just want you to follow the simple labeling on the panel to complete the task you desire.  However the red lever is the lever that will bypass the Alde, ie the hot water tank.  Here is a link to the Nautilus manual that does a good job telling you what each lever does.
    https://us.v-cdn.net/5021717/uploads/editor/py/2wdph8ajpgb7.pdf
    When you look at the manual you can see if you follow the "Winterization" instructions the Alde will be bypassed. The manual shows you how to first blow out the lines then fill them with antifreeze.  I skip the blow out and just use -100 prestone antifreeze where I live as the standard antifreeze is not good enough with the temps we have.
    2021 T@b 400 BD  "Vixen Gail"
  • Jay_and_KatJay_and_Kat Member Posts: 271
    Hmm, now I'm somewhat confused, as the nuCamp manual for for the T@B400 does say there's a bypass valve, I'm presuming for the hot water tank.
    Unless, what I'm thinking of that I saw, is the SHUT-OFF valve for the hot water...
    Time to crawl around the T@B, I guess.
    Jay and Kat
    Good catch Jay_and_Kat!  I emailed nuCamp regarding this manual error.
    The red lever in the Nautilus compartment will bypass the Alde, hot water tank.  It is the bypass valve just not labeled as such.  Vertical and water will enter the Alde, horizontal and water will bypass the Alde but will flow to the hot water taps.  That is why when you winterize with antifreeze you turn it horizontal prior to pumping in the antifreeze as indicated in the winterization instructions.  Nautilus does not label it as a bypass as they simply label the all the valves under different categories such as winterize, dry camping ect. I'm not sure what manual you are looking at but it may reference the older 400, prior to 2021, that did not have the Nautilus and did have a red lever labeled as the bypass.
    One last question then on winterizing, about how many gallons of antifreeze will I need?  I'm thinking, based on the guide @Sharon_is_SAM linked to, about 4.5-5 gallons?
    Jay and Kat
