T@B Tent Attachment
Jimbo
Member Posts: 118
Anyone purchase the $795 attachable tent? What do you do to protect the floor from pokes and holes from sticks and stones?
Jim, Kelseyville CA, 2013 T@B "Q", T@BCASA, Silver W/Yellow trim, TV: 2006 Honda Ridgeline
Thanks Sandra - wouldn't a rug/blanket under the tent floor do more to protect the tent flooring?Jim, Kelseyville CA, 2013 T@B "Q", T@BCASA, Silver W/Yellow trim, TV: 2006 Honda Ridgeline
Wouldn't you just put a tent ground cloth below, like you do when your normally camping in a tent. Also, like tent camping, make sure your ground cloth is smaller than the tent, that way water running down the sides, won't pool below your tent.
I put my mat on top of the floor. I've never had issues with rocks damaging the floor of the ThermarestCrystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.
Paha Que sells both a footprint for below as well as a rug for inside if you are interested.jdargis said:Wouldn't you just put a tent ground cloth below, like you do when your normally camping in a tent. Also, like tent camping, make sure your ground cloth is smaller than the tent, that way water running down the sides, won't pool below your tent.
I ordered the footprint from Paha Que. It seemed pricey but when it came I understood--it's not the typical plastic dropcloth, it's actually sewn out of heavy nylon, sized specifically for the T@B tent.Doug
Des Moines Iowa
2016 S Max Sofitel -
Didn't know about the footprint from Paha Que so we purchased two plastic tarps for under the tent room and an outdoor mat for inside. We've used the tent room during our two trips so far for 11 nights and have enjoyed it.Chris & Gina
2015 T@B S Max Sofitel -
If the ground looks like it could potentially damage the floor, I put one of those plastic RV rugs under the tent.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
