Draining Fresh Water
jbajor
Member Posts: 233
When I drain the fresh water tank using the drain valve, will this also drain the pump? I do not want to have to go through re-priming the pump from taking it dry.
Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California
Volvo XC-40
I'd love to get your process for 'priming' the pump when/if needed....Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California -
In my experience draining the tank will require re-priming the pump. There is no "process" per se--the pump should be self priming--but the process will introduce air into the lines that will need to work itself out when you open the taps.
I've never had to prime the pump on my 2022 after draining the water tank. I empty the fresh water tank and open the hot and cold water low point drains after each trip.
- 916 Introductions
- 72 Teardrop Groups & Links
