Porch Light LED swap
Hi from Minnesota.  Today I swapped out the factory halogen bulb in the porch light fixture with an LED.  I've attached photos showing the original bulb, a side-by-side view of the halogen and LED, the installed LED bulb, and a snap of the part number.
Once you get the cover off it's a very easy install. Pull out the halogen and then insert the LED.  The heat shield/reflector does need to be either removed or bent upwards.  I chose the latter in the event that I go back to the halogen.  Not sure why I'd need to do this but just in case I decided not to remove it.
If you look at the installed LED photo you can see the how it looks.
http://www.m4products.com/g4-12-5050-side-ww-warm-white-g4-t3-retrofit-led-light-with-side-pins-replaces-10w-halogen/
I went with the warm white but they also have natural white and cool white.
2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
  • Nomad
    Nomad Member Posts: 7,209
    Hey Spruce1 - What year is your T@B?
    There's a thread from roughly 6-months ago where they also replaced the porch light. -Can't remember what year T@B that was though.
  • jkjenn
    jkjenn Member Posts: 6,423
    I think it was @Michigan_Mikeputting an amber light in.
  • JandJ92010
    JandJ92010 Member Posts: 304
    We air brushed the inside of our lens with yellow translucent paint from Hobby Lobby.  (It still attracts bugs).
  • Spruce1
    Spruce1 Member Posts: 100
    Hey PXLated- Ours is a 2014.  The only other thread I found was a swap out of the socket on a Silver Shadow (Michigan Mike's). That involved doing some minor rewiring.  For mine I found a LED retro fit bulb that fits in the existing socket.  The bulb I got is white.  It's weird that the new bulb appears amber when off, it's actually white when illuminated.
    2014 T@B-S
    Minnesota
  • Luigi
    Luigi Member Posts: 31
    Following NuCamp's directive, we bought the amber porch light from our dealer (TAB 400) and paid quite a lot. $45.00 for the light, shipping/handling, taxes, came to $56.00. People at Ucamp last year bought theirs for >$20.00. We're putting it on ourselves to save $$.
  • ChanW
    ChanW Member Posts: 3,165
    We put in a retrofit LED bulb when we first got the Tab. I tried a few before I found one that was dim enough. We wanted to avoid lighting the whole woods with it. Ours is an earlier Tab, so the fixture might be different for later ones.
