2023 T@b 320--what's new?
KTOT
Member Posts: 35
Anyone have a list of the changes to the 2023 T@b S Boondock? Other than the lithium/AC option.
No, big mystery to me.
The only other changes are the dark sidewall option and it now comes with the Nautilus P3 instead of the P2. Here is a short video of the changes to all the campers in the NuCamp line.
https://www.youtube.com/watch?v=0JgM4qX6pDM
2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
Just got back from a RV show that had the 2022 320S BD and 2023 320 CS-S BD. The new P3 Nautilus has one water inlet and the new valve is white and does the switching of inputs. Also has the quick disconnect shower. BUT there was no Alde bypass lever... I and the salesmen could not find it. Also the tires were Goodyear Wrangler AT 235/75 R15, I was surprised as I didn't think these were trailer rated. Also noticed the Fantastic fan did not have the lock down clip and the pivot arm seemed different. The Battery disconnect was moved to the place I mounted my storage Lagun mount (by the door) - dumb but allows more wiring to be contained in the cabin when going to Lithium so that's smart.
managed by VE Smart Network -
Mark, the red valve handle is the Alde bypass valve, vertical is normal and horizontal is bypass mode. Note, the Nautilus display shows the red valve in the vertical (non bypass) mode for Sanitize mode, which is correct, as the blue valve is set vertical to prevent the flow of bleach solution from going to the Alde hot water system.
Edit, see Sharon-is-Sam discussion and diagram here: https://tab-rv.vanillacommunity.com/discussion/11969/tab-400-boondock-2021-winterizing#latest
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Thanks read that on the other thread - didn't realize there were two threads when I posted. Didn't have my glasses on when looking at the show so missed the fine print for the red valve. This and the move of the low point drains by the gray valve make me envious of the '23 model. Those low point tubes to the valve on the '21 are leak problems - probably why they went to the new location on the '22. I was surprised they switched to the Goodyear Wrangler - a lot easier to replace but I wonder about the trailer rating? Also got a kick out of the missing cover lock that breaks so often on the Fantastic Fan.Snohomish WA, 2015 Diesel Grand Cherokee
@MarkAl, Sharon pointed out an error I had in my previous posts (which I corrected), the red Alde bypass valve on the Nautilus diagram is correctly shown for Sanitize as the blue valve is changed to prevent bleach solution from going into the Alde hot water lines and both tanks. So the red bypass valve doesn’t need changing, as the blue valve does the same job. See Sharon’s diagram I referenced above.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
