Hello! I have a 2022 tab400 and just went through my first test run of the winterization process. I have a couple of questions that I'm hoping you can help with.
When I open the drains, should I turn on the water pump?
During the draining and blow out process should I work it until there is absolutely no water coming out? I went through it but it seems like there is always a little spitting/dribbling.
Thanks for your help!
2022 TAB 400 BD / 2019 Honda Passport / 2023 Land Rover Defender / Cumberland, RI
0 ·
