Cleaning tree sap off boondock flooring??
PNWtabber
Member Posts: 492
Just got home from Mount Rainier National Park and I guess I stepped in some tree sap because I have it all over the floor of my 2018 320S Boondock. Any tips for cleaning the sap off the floor without damaging the flooring?
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
The flooring brand in the Boondock for your model year is Marmoleum. Start with 50/50 vinegar and water, which is the most common recommendation for that flooring brand; if that doesn’t work, Google should have other options for you, including specialty cleaning products.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
Since you have the Marmoleum floor, which is a very tough commercial flooring, try in a small area first, using some woodworks saw blade pitch remover soap, or a good citrus based degreaser soap, both are good at removing pitch. A light bit of scrubbing may be required with a fingernail type brush. Rinse throughly and Bob’s your uncle...
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1 -
I have used Goo Gone on other vinyl flooring..not in my T@B. It removes about anything without damaging the surface.2
I'm back to my suggestion of an alcohol based hand sanitizer gel. It works great on exterior paint and I can't imagine it will hurt the floor. Try it first on a non-obvious spot just to be certain.Dan and Liz 2019 TAB 400 BDL 2010 Toyota Tacoma V6 4WD TRD Sport0
Thanks for the suggestions. I tried the vinegar method today, @VictoriaP. It took away the stickiness, but I can still see where the sap is (was?). I'll try rubbing alcohol tomorrow and see what happens.2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman0 -
Goo Gone makes a variant to take sap off of car paint. I’ve used it and it works pretty well and I think it would be safe on the floor.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI0 -
rcuomo said:Goo Gone makes a variant to take sap off of car paint. I’ve used it and it works pretty well and I think it would be safe on the floor.
I don't have any Goo Gone on hand. If the rubbing alcohol doesn't work, I'll go get some.
