Spare tire question, 2018 T@B 400
Deb55
Member Posts: 293
We have a 2018 T@B 400 with the original tires. I believe they're dated November, 2017. From what I read, it's time to replace them even if the tread still looks good. They see a lot of sun in our driveway during the summers. I want to get Goodyear Endurance tires. Before I order them, should I get 2 for the trailer, or should I get another one for the spare to match? For that matter, is the spare on the 2018 T@B 400 the same size as the regular tires? I tried to look underneath, but I couldn't read the sidewall. Thanks!
When I replaced my original tires on my 2018 Tab 400 with Goodyear Endurance tires, I replaced all three tires. The tires are all the same size.2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts -
Thank you, @DenisP! Always helpful!
Always good to do all three and have them match. You got four plus years out of those tires, not bad…. But time to replace them, to be safe.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
If tires are covered when the trailer is not in use; how many years might they last?400 - 2019
St Catharines, ON -
I cover my tires with those Camco covers. I don't know if that is going to extend the life or not. If you see any cracking on the sidewalls then you should consider replacing the tires regardless of the tread depth. I replaced my original "China Bomb" tires with Goodyear Endurance P225x75R15 sized tires.
The OEM tires are good for two to three years, as the rubber oxides and starts to break down. Sunlight can make this happen quicker (2-years), but if no checks are visible, I would still replace after four years.
@Denny16
If there are no sidewall cracks and the tires are kept covered, why would you replace them at four years? Just curious.Rich2019 T@b 400
Trailer tires just become unreliable as they get older (due to oxidation and temperatures during storage), regardless of tire wear. Going down the road at highway speeds on old tires is an accident wait happen, and this has been documented. My only on the road breakdown with a failed tire, was on a tire that was more than four years old. Trailer specific tires are not made to the same standard as car/truck tires. That said, all tires deteriorate over time, even expensive sports car tires…Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
