We have a couple of mornings forecast with possible hard freeze here in Minnesota, then we are leaving next week on an extended trip. Can I drain the plumbing and still use the Alde heater to keep the interior warm?
More specifically, will draining the plumbing also drain the Alde water heater and therefore damage the water heater section when turned on? Propane or electric Alde supply make any difference?
Douglas
Minnesota and Arizona
0 ·
No problem running the Alde on electric or propane without water in the tank. The glycol heats up and will circulate around the trailer for your cabin heat. If there were water in the tank, then it would heat up as well. It's an all-in-one system (heat/water) vs others that have separate hot water heater from heating system.
Southern Maryland
Douglas
Drain the hot and cold water lines. Let the (full) fresh water tank drain with a slight dribble through the night, thereby protecting the tank drain valve without emptying the tank. Heat the 2022 Tab 320 BD cabin with the propane/Alde system. I've got two 100 amp Battle Born lithium batteries in the exterior front tub, understanding that they have circuitry to protect themselves from charging when below freezing.
What do you experienced Tab folks think? Many years of RV'ing here but first time with Alde and lithium batteries in freezing temp's.
Douglas
Our route next week will be somewhat weather dependent and most probably consist of several nights boon docking on the first leg, about 15 days total to our place in Arizona for the winter. We plan to head for Monterey, Ca and follow the coastal highway to San Diego, camping at military installations along the way.
Douglas
If you are using the Alde for heat, you can leave water in the water tank and water lines on non CSS model TaBs, as the Alde will keep the hot water tanks from freezing (Alde control panel hot water in normal (one arrow) setting), even if the temp in the cabin drops to 30F. The PEX water lines will also tolerate a short exposure to temps in the 30s without breaking.
I now carry a Pex repair kit in my tools.
managed by VE Smart Network
