Knob on Round, Undersink Cabinet T@B 400
On our way home from recent trip, the pewter/nickel knob on the circular cabinet under kitchen sink must have rattled off. Figured it rolled under WFCO opening or possibly under bed. After significant probing with 3' long x 1/4" diameter fiberglass pole, we came up with nothing.
Has anyone else lost one of these? Like a lot of trailer items, it's probably generic -- but naming it in a search is the tough part. The inner bolt end appears to be 1/8" or metric equivalent. The outer opening (for male end to fit through) is about 1/4". Have a feeling it would consume more time than its value to call a dealer.
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X  Tucson, AZ
  • Denny16
    Denny16 Member Posts: 5,431
    You might be able to get the part number from nüCamp Customer Care.  As for where your lost knob may have gone, look under the dinette area, and around on the entire floor area.  Not likely it rolled under the rear bunk, but you can lift up the bed to find out, and see if it is in front of the Air8 AC.
  • johnfconway
    johnfconway Member Posts: 295
    Thankfully, no Air8 in this puppy! Did check under bed. Cleaned entire floor. A/C flex duct in area under WFCO. Probed it and came up with nothing. Will try Elsie in customer service next week.
  • Denny16
    edited October 2022
    This is a mystery…. Forgot John, you had the Air8 replaced with a CoolCat.  Good luck with the replacement.  The same latch knob on my wardrobe locker does not go flush when pushed in to lock, going to check of it screws back in, before it falls off…
  • johnfconway
    In the unlikely event you too manage to lose this knob, the "where/how" to replace it is in this discussion: https://tab-rv.vanillacommunity.com/discussion/10537/tab-400-cabinet-button-latch-upgrade
    The part number from NuCamp for this knob matches up with other "push" knob assemblies.
  • Denny16
    edited October 2022
    John, the one other space it might have rolled or slid under is the front passenger side dinette seat.  It turns out my wardrobe locker push knob just screwed back on flush, so thanks on the heads up these knobs can screw loose.  Hope you get a good replacement or find the lost one.
  • johnfconway
    @Denny16, it's replaced! Now the original can roll out of its hiding place. In a past life, that knob was a sock in a dryer!
  • Denny16
    When it shows up John, you will have a spare!  B)
