AnneLark said:YEA!! Going to go get an extension cord!! Hope that fixes my battery problem!
@AnneLark, do a search (upper right hand corner) for dead battery or recharging battery or phantom draws (one word searches are better). There are many, many discussions already here about how to take care of your battery and about the phantom draws of the different "parts" of the T@B. We've discovered many ways to keep the battery above the 50% mark. We, here are this forum, discover ways to help all of us.
Please do not blame the manufacturer of the T@B. Once you buy a vehicle, the battery maintenance is your responsibility, as it is on the T@B.
Not sure if you have the 2-way or 3-way fridge. The three way fridge burns a lot more battery when run on battery than the 2-way. I am going to assume you have the 3-way, since you have the S-Maxx.vito said:I was told that driving for as little as 45 minutes was enough to fully charge the T@b's battery, but then again, I'm finding that much of what I was told by the technician at the dealer may not be correct. Before I leave for a camping trip I hook up the shore power, primarily to get the refrigerator cold. Then it runs on battery power while I am driving, and then again on shore power when I get to the RV park. Only when and if I ever boondock will the battery really matter. Although I do admit that if I decide to spend a night in a Walmart parking lot, I would expect the battery to power everything on the T@b with the exception of the air conditioner, and if the battery is not up to doing that much it would be a real problem. And I also wondered what would it cost to replace the T@b battery? I have no idea of the cost of this size and kind of battery.
thanks again... Vito, you may want to consider 2 6 volt golf cart batteries wired in a series. It will give you a lot more capacity. After that would be solar.
John
2007 T@B
Rockford, IL
2007 T@B
Rockford, IL
