We are in the middle of changing out out Alde glycol. We bought what we thought was Rhomer rg rtu 50, but the container is labeled Jeffcool P-150. The seller says it’s the same stuff but the internet says it’s red.
I can’t get thru to Truma. Does anyone know anything about this glycol.
We have completed all steps (drain old stuff, rinse with water and then distilled water). It was just then when we noticed different labeling.
now we’re scrambling to find Century TF stuff since we’re expecting hard freeze this weekend. No one seems to have the Rhomer in our immediate (driving) area including Nucamp dealer n Missoula. Instead, I can drive 3 hours to Missoula to get 4 gal of Century for $85 per gal.
will be calling Truma tomorrow AM in hopes they say the Jeffcool stuff is ok.
very frustrating, after the drain and rinse went really well.
@Sagiller, I'm not familiar with the 320 circuit, but can you get to both hoses off the reservoir and use a shop vac to pull the remaining distilled water out?
The service guys I talked to at the NuCamp dealer in Missoula did not know much about the changing of the glycol, or why they can’t get Rhomer. I don’t have much faith in them now for anything nucamp.
A gazillion thanks to the creator of the great How To pdf. We had no problems doing all the steps. A tip we figured out is to run the output (excess) hose outside the camper via the outside shower area. We could flush everything out into a bucket and not worry about spills inside.
