alcohol free antifreeze/not available in my county
The ethanol free antifreeze does not exist in my area.  Nucamp recommends a brand called Purf Century.  Do I absolutely need this ethanol free antifreeze for my 2021 tab 400 boondock for winterization?
  • Denny16
    Denny16 Member Posts: 5,430
    Ethanol is poisonous if you get some in you.  You are pumping this stuff in your water lines…  Your call, but personally, I wouldn’t use the stuff in my water system.
  • techietab
    techietab Member Posts: 161
    Poisonous, technically, but...most of us drink low concentrations of ethanol recreationally. It's isopropyl (rubbing alcohol) and methanol (wood alcohol / bad distilling byproduct) one usually might encounter and want to avoid.
    @PaulKethley - the short answer here is 'no', you don't. The ethanol that's present in many brands of RV antifreeze will accelerate breakdown of rubber gaskets/seals, but it's not going to do so in a single season. I'd avoid if if possible, but if it's not an option, this is a 'something is better than nothing' situation. You might also look into the 'blowout' method (search here on the forums) as an alternative method for winterizing.
    Northern VA
    2022 T@b 320 S / 2021 Subaru Outback
  • BrianZ
    BrianZ Member Posts: 1,770
    @PaulKethley, I  assume you may be referring to this..
    https://www.centurychemical.com/winter-pruf-antifreeze/
  • BrianZ
    How about this Prestone RV antifreeze..
    RV/Waterline Antifreeze RVs, Pools, Boats and Seasonal Homes - 1 gal (-100° F) https://a.co/d/1BQaXJR
    Says safe for water system components.
    Cheaper at a local Walmart.
